Atlantic City - Hoboken NJ in two days?
xavpil
Sep 6, 2022
376
Jeanneau Sun Odyssey 419 Milwaukee
Hi all. Planning a sail between AC and Hoboken. 18 hour sail
I don’t want to do it in one trip (for multiple reasons I don’t wish to discuss here) unless there is nowhere to stop of course
My sailboat drafts 5.5 “
If you can share your knowledge or even better your experience that’d be great!
thx all!!
The stops for a leisurely pace would probably be Barnegat Inlet and Sandy Hook, weather permitting. Barnegat can be a challenging inlet in marginal weather but in calm conditions is fine. @Scott T-Bird might have more insight on that. Sandy Hook is very accessible and allows stopping about 16 miles before Hoboken. In an easterly wind if the tide is outgoing at the inlets you might just need to go all the way from AC to Sandy Hook rather than trying the inlets. The other possible inlet is Manasquan which is probably a little more accessible than Barnegat, but I’m not aware of any great anchorages to spend a night there.
Likes: xavpil
Oct 26, 2008
6,277
Catalina 320 Barnegat, NJ
When is your trip? Are you in AC now? It looks like we have fair weather and flat seas for at least the early part of this week.
Depending on how much time you want to take, the prettiest anchorages, hands down, are Barnegat Light (called Myers Hole), and Sandy Hook Point. If you want to take the time, I would spend a night at each and make 3 very easy days to cover the distance.
Barnegat will fall well short of it's nasty reputation right about now. The channel markers start well outside of the inlet and are very easy to find on a clear day. There is no need to start in at the outer pair (I see them marked "1" and "2" on navionics. I usually cut into the channel at markers "3" and "4" and head straight for the northern half of the opening between the jetties. The ends of the jettyies have fixed day markers "7" (green) on the south jetty wall and "6" (red) on the north wall.
Tide is high in the afternoon for the next several days, so the north jetty will be submerged when you approach. DO NOT pass #6 with the marker and the jetty on your port side! You will be on the rocks. You will see a lot of small skiffs fishing in that area. I don't see #5 on Navionics but I suppose it is in the middle between the jetty ends. Sailboats always stay to the north half of the opening. You will easily find the channel markers as you are passing through the inlet. It looks like currents are flooding in the later afternoons this week. Outgoing current is 3 knots so you will want to avoid max ebb currents that will be closer to noon. Slack currents between ebb and flood does not coincide with high tide. Slack current occurs about 3 hours earlier than high tide, so it is best to ride in at the end of a rising tide, which will be late afternoon this week. You can sleep in before leaving AC.
Within the channel inside markers #3 & #4 it gets shallow and you will see small breaking waves surrounding the channel and even inside the channel. If you stay within the marked channel, you will see depths get shallow to just under 10'. Locals typically round the channel entirely to the north side and only veer into the inlet right next to the end of the north jetty wall (which will be underwater - but the day marker is clearly standing out). Navionics shows the deep water very clearly when navigating around the north side of the marked channel. You may see boats heading toward the beach north of the wall and wonder why they are steering to the north of the channel, until you see them cutting inside just outside the end of the north jetty.
Once inside, Myers Hole anchorage is just between the Barnegat Light and the High Bar Peninsula. You'll find boats anchored there and within that area are some private moorings. A few weekends ago, our club had 14 boats anchored in Myers Hole, so there should be plenty of room when you are there.
Manasquan Inlet is more centrally located if you want to make just one overnight. I've never been in there so I don't have anything to say about it, except that I think you won't find an anchorage inside the inlet. You can stay at a marina, but you may have to navigate 2 bridges once you are inside. The inlet is easy and straightforward. I've heard that the marinas are very nice, expensive, and rolly because there will be a steady stream of sport fishing boats going both directions at all hours. (Barnegat has a commercial fleet of large fishing boats and party fishing boats that can also be a source of noise and waves throughout the night - but I think they are considerably more considerate!)
Sandy Hook point is a good anchorage just inside the end of the peninsula! It's just outside a coast guard station at Fort Hancock and the Sea Streak ferry service may come through there, but I think mostly on weekends. There is no need to go all the way inside to the Highlands anchorage. It is secure and protected just inside the point - as long as wind isn't from northwest. It should be fine this week!
xavpil
Sep 6, 2022
376
I will be in Cape May this coming Friday and reach AC on Sat. 6/8, then Barnegat and maybe straight to Sandy Hook it seems like because I don't want to spend money on a marina, but at least if the weather turns, I know I have an option to stop.
What a comprehensive answer!!!!!! Thank you so much for taking the time to share your knowledge!!!!!
I am not really looking forward to the trip!
xavpil
Sep 6, 2022
376
thanks David for taking the time. Super helpful!
xavpil
Sep 6, 2022
376
Barnegat will fall well short of its nasty reputation right about now. The channel markers start well outside of the inlet and are very easy to find on a clear day. There is no need to start in at the outer pair (I see them marked "1" and "2" on navionics. I usually cut into the channel at markers "3" and "4" and head straight for the northern half of the opening between the jetties. The ends of the jettyies have fixed day markers "7" (green) on the south jetty wall and "6" (red) on the north wall.
Made it to the amazing anchorage
You are right, (thx again for the detailed info), the inlet is not super terrible
Today weren’t great conditions
I arrived mid afternoon, almost end of ebb with 25/30 knt wind but in the nose.
i am so glad you mentioned the rocks on the right because the big incoming waves were pushing me until I saw the top of the rocks and remembered your note!
I’d say based on my experience these rocks were the only big challenges.
Of course the typical big swell waiting to take you on the side if you are not vigilent
Pretty intense still. Kept my engine pretty high to match the waves speed.
Wouldn’t recommend it to a novice.
Likes: Scott T-Bird
Oct 26, 2008
6,277
Glad you made it inside safely! Winds were very strong from the west all day Saturday. I didn't stick around to see what Sunday was like. I hope you had a chance to get off the boat and see Barnegat Light. It is really a great little town with some local character. Being at the far north end of Long Beach Island (LBI as everybody knows it) it is more removed from the commercialization of the central island locations. It's more quiet and scenic and really a great stop-over once you get passed the nasty reputation that the inlet has. It's a great destination for those of us arriving from Barnegat Bay but it is a long, long channel to get to Myers Hole from the bay and there is a steady stream of power boats in all sizes cruising in both directions.
If you haven't left already, you will find it convenient that you can veer north as soon as you clear the north jetty wall at #6. The shallow water in the channel always makes me nervous when there is a good swell and the depths start to read under 10'. Locals steer to the north after clearing the jetty because the deeper water makes a smoother passage beyond the breakers. It can get very bouncy if you stay inside the markers all the way to the outside. Leaving on slack or ebbing current close to high tide is always the best way to go. The trip to Sandy Hook should be no more than 10 hours unless you have a nasty chop against you.
xavpil
Sep 6, 2022
376
unfortunately this was only a stop for the night. But I know we will come back because the beach and anchorage were so stunning
Thanks again for the help. Without you I wouldn’t have attempted the inlet and would have missed on such a beautiful place!
Oct 26, 2008
6,277
Glad you liked it! If you haven't left yet, see my added comments above about leaving the inlet. Obviously, the most common mistakes that some boaters make is not paying attention to the submerged jetty on the north wall during high tide. Even very experienced sailors (but not familiar with the inlet) have been on those rocks and either sunk or damaged their boat in that location when they were not watchful enough to see the end of the jetty.
