asym set up
You've already got the spin halyard so all you'll really want to add are some blocks near the stern for the sheets and an adjustable tackline to control the height of the sail's tack. My asym came with a sleeve that wraps around the furled jib, but I don't normally use it because you have to go all the way forward to hook it up. (I'm not sure if it's good for the foil either.) Anyway, I like to let it fly free with the tack just above the pulpit for beam reaching, a little higher for broad reaching. A bowsprit would really be cool... maybe someday. I also have a dousing sock, spinnaker sleeve, chutescoop...whatever you call it. For single handing, it's handy for dousing, but somewhat inconvenient for setting. The problem is that it's difficult to manage from the cockpit, but very easy from the foredeck. Check out any literature on this device and you'll always see a crew on the foredeck operating the chutescoop. The skipper is in the cockpit controlling the halyard, sheets and tackline. I think these things are designed for cruising couples on mid-sized boats who would have trouble with a large sail. For a smaller boat, under 30 feet, I think it's easier to use more traditional methods of setting and dousing. Such as launching from a turtle on deck and dousing by releasing the halyard and tack line, then retreiving the sail with the sheet back into the cockpit.I still use my sock, btw, but I've rigged everything so I can set the autopilot and just make one trip to the mast, then back to the cockpit. The sail is hooked inside the forward hatch, the hatch dogs are taped so I can open it from the outside, there's a cleat on the mast to tie off the halyard, and a vee(clam) cleat to set the tackline that can be released from the cockpit and finally a another cleat to tie off the sock's control line. Dousing is very easy, just release the tackline, snuff the sail and lower back into the open hatch while standing at the mast.Finally, the CruisingDirect.com site has a lot of information, and pictures, on how to set and sail your spinnaker.
