Input from a newbie
Pat,I have a Pearson 303 and it's the first boat I've had with a spinnaker, so take my input with a grain of salt, okay?
I have a shackle at the base of my forestay (yep, just good old fashioned bow shackle.) I run the tack line through that to a cleat. I adjust it so that the tack is about 2" above the bow pulpit. I have a dedicated spinnaker halyard that runs through a masthead sheave. There's an exit plate above the main halyard on the starboard side and a clam cleat on the mast to secure the halyard. (yes, it's all pretty low tech - but simple.
)I do have an ATN sock on my spinnaker which helps to simplify all of this a bit too. I run the sheets outside of everything, then raise the sail/sock. It worked pretty well the first (and so far, only) time I did it. Now, the PO showed me this setup, so I can't say that it's 'right', just that it works.I am going to add a couple of blocks to the stern pulpit so I can account for the clew (and sheet routing) a bit better. I imagine I could make a bow sprit or create something to have it off the bow pulpit, but I'm not a performance sailor - I just like to cruise and have fun.If I had to tack or gybe I'd go forward, sock it, do my thing and un-sock it. Given how it's setup now, I wouldn't have to adjust the tack or anything.Just my two cents...Dave CrowleyWind Dreamer II
