doug
how close to and how far off the wind should one be able to use the a-sail? in, other words, if the wind is blowing from due north, 360 degrees, what tracks should i expect to sail?i've only tried this sail in very light winds, and only on broad reach, but was suprised that the sail collapsed when trying to "run". if the wind was from 360, the sail would collapse when the track was turned greater than 150 degrees. is this to be expected, or do i need to learn how to trim better?i haven't tried the sail on a beam or close reach. is that possible?thanks.doug
