Mauro C. Dal Canto
I have a 1994 Hunter 40 which is a joy to sail in the unpredictable waters of Lake Michigan. The only problem I see is in its different handling on port versus starboard side, when pointing close to the wind. While on port side I can go as close as 30 degrees from apparent wind with no luffing at all, on starboard side, it starts luffing, the main before the jib, at about 40-45 degrees no matter what I do. I suppose no boat sails perfectly symmetrical, but this seems a bit excessive of a difference. What part of the rigging should I tigthen or loosen to make it as close to symmetrical as possible? Or is the solution in something else?Thank you in advance for your reply.Mauro C. Dal Canto
