Peter,
ATN tacker works great since it comes with the appropriate clips and floats if it falls in the water unlike the parallel beads I purchased (they sink if they slip out of your hands and fall into the water). The tackline either can be lead from the tack of the sail, through a block as far forward on the bow as you can get it (I use the bow roller), and then back to the bow cleat (this is what I do) or all the way back to a cockpit cleat, with enough purchase that you can adjust it under load. The benefit of bringing it to the cockpit is that you can adjust the height of the tack off the bow, otherwise if tied off at the bow you have to set its length based on wind speed. Things will be simplest of you plan to hoist the sail on the same side of the forestay as you led the tack line. Tie off the tackline with enough slack that the tack of the aspin will be able to fly several feet above the bow. I do not run mine to the cockpit since I did not purchase that extra line and it works fine tied off at the bow with a short line. Suggest setting up the aspin at the dock.
Cheers, Steve
