Asking for advice on a 1985 h31 purchase
Aug 5, 2009
333
Hunter h23 Dallas Tx.
I took several big boat friends to look at a 1985 h31 today. The owner was not there but we were able to go aboard and spent several hours inspecting it. The boat is in the water. We also talked to the marine mechanic who has serviced this boat for the last 6 years. Any h31 owners have any advice?
Feb 22, 2004
222
Hunter H340 Michigan City
Check the compression post most have rot issues. Also a keel smile issue on most. My h31 1984 has both fixed. Well keel smile still needs a little love every fall but it is getting to be less and less. Other than that no mechanical issues. Open the weep hole to let the space between the liner and hull drain and it will smell better. It is a great boat we love ours.
SFS
Aug 18, 2015
2,088
Currently Boatless Okinawa
Keith, where is this weep hole you speak of?
CJones - We have owned ours a whopping 14 days, and really like it. It feels roomier than a C30, turns in its own length without any special handling, and feels like it will be fast, once the bottom is cleaned. Perforated toerail is something I didn't know would be so useful. Small thing, but it gives a lot of possibilities. It is a little bow tender, so that takes some getting used to/pre-planning at the dock.
pateco
Aug 12, 2014
2,207
Check the compression post. Walk the deck, and check for any soft spots or obvious damage.Take it out if the engine runs, check for vibrations and leaking at the stuffing box. If you have a mask and fins. take a swim under it , and look at the condition of the keel rudder, strut, shaft, any thru hull screens, speed and depth transducers and propeller. How badly is the hull fouled with marine growth? Turn on the water pump, and check pressure and water flow to the head and galley. Check the water heater, Does it work? Check plumbing on the head, and make sure the waste lines are run to current requirements. look at the opening ports. Are the seals ok are the ports leaking? Do the instruments and radio work. Take a look behind the breaker panel. does the wiring look neat and organized, or has it been spliced to hell? Does shore power work? Is the battery charger working? What condition is the standing and running rigging in. Are the sails OK, and what sails come with it. What kinds of spare parts are already aboard? and many many more.
We have been restoring a Free 1983 H31 The for over a year now, and as a free boat a lot of these items needed attention Our compression post had already been fixed though, and we had no soft spots on the deck.
Looked like this when we got her.
Looking like this after 1 year of fun.
Check out the link below for information on our ongoing restoration.
Aug 5, 2009
333
Thanks everyone for your replies. pateco, great looking job on your boat. Having researched the h31 prior to going look at it I knew about the compression post rot issue, the rudder problem and the rust at keel to hull joint. No rot on this one or it was repaired prior to this owner purchasing it 6 years ago. I will take my hookah dive machine with me when I meet with the owner next week. The floor has a few panels that are a little soft but they look original and I expected this. Deck has no soft spots. I,ll wait until after my dive to make a final decision on the purchase. I will have a bottom job done when its hauled out to move it to my lake and polish the hull
Feb 22, 2004
222
The weep hole is forward in the bilge. I elongated mine. poured a dilute solution of water and bleach in under the V berth it ran out and into the bilge wow what dirty stinky mess then used the hose to flush it. The smell was much better now I pour some vinegar in once in a while and the stink is gone.
Mar 28, 2014
51
Hunter 31 Lake Norman, NC
I have an H31, '94 and i'm not familiar with the weep hole. Can I get a photo?
