Josh
I have been working on figuring out out to ascend my mast if I were soloing at sea, and the more difficult part, letting myself down again--descending with ascenders down right sucks. Here is what I came up with. First, get two ascenders (also called jumars) at REI or somewhere that sells climbing gear. Tie one ascender to a climbing harness or bosuns chair--the amount of rope between the harness and ascender should be enough so that when its attached, the ascender should reach your neck. Then make a foot hold also attached to an ascender. This one should reach your waist. (I just use a big loop, but you could use a daisy chain, or real foot loops, or make what's called chicken-loops to stick your feet in. Then you inch-worm up, stand, sit, stand, sit. So far, there's nothing new; the guys who recommend ascenders in previous posts mentioned all that, except the length of rope between ascender/harness and ascender foot hold. Now you put a belay device (called an ATC) on the halyard below the lowest ascender, the foothold ascender. You have to leave the halyard you are climbing up uncleated on the bottom--otherwise the belay-device would keep you from ascending. As you inch-worm up, you pull in the slack on the belay-device as well. The motion is like this: stand, raise harness ascender, sit, raise foot ascender, pull in slack on belay device, repeat. When you reach the top of the mast, you tie off the exiting line from the belay device so that you can put weight on it without sliding--a slip-knot is best, something you can release under pressure. This slip-knot is not important for working on the top of the mast, but becomes important when you need to remove the ascenders in order to use the belay device to rappel down. To come down, you stand, remove waist ascender from halyard (and just let it drop, since it's attached to your harness)--since there will be no pressure on it, grasp the exiting line from the belay-device with both hands; take out slip knot, which should have no weight on it since your standing on the foot ascender. While holding down firmly on the exiting line from the belay device, put all your weight on the belay-device--you should be completely braked from the friction of the device--remove feet from footholds--preferably without using your hands--that's why I use a big loop, and just step out of it. Then carefully remove the ascender from the halyard with one hand while you firmly hold down the line exiting the belay device to remain braked. Clip the ascender onto your harness, and rappel down. I've been practicing this at a climbing wall, which I recommend, a bunch of times, before trying it while you're soloing out in the big seas. Take care all,Josh
