Are zinks needed on h23 in salt water
2
Hunter 23 Paris Texas
I'm preparing an h23 to go coastal. Do I need to put zinks on the keel or motor? Thanks jim
Oct 3, 2006
1,029
Hunter 29.5 Toms River
I would
however, regarding the bonding scheme, I know somethign should be done, just not sure what. The 23 does have minimal electric - just nav lights, radio, cabin lights.
Mar 23, 2008
66
Hunter 26.5 Urbanna, Va.
On my 26.5 ...
... I have a zinc on the outboard because it has an electric starter that is, of course, wired to the battery. I hasn't thought about a zinc for the hull as (for one thing) there is no place to mount one. The folks at Hunter didn't put one on at the factory.
Apr 22, 2004
2
Thanks Brian & Cap'n
*o --- Aweigh should be pretty well isolated from the salt water. After alot of work brightening the wing keel I put 2 coats of ospho/3coats of primocon/3 coats of VC Tar trying to isolate it from the wet ---no metal is immersed except when I lower the 5 hp Tohatsu and it's not grounded to the keel. I'm thinking of just getting one of those zink groupers. Battery/electrical system is not tied to keel bolts anyway. lightning ground consists of a split set of battery cables clamped to the shrouds. If I get zapped or my keel melts -- I'll try something different. Thanks for the input jim
