Although the pros and cons of variable mast bend (through backstay adjustment) as a tool for controlling sail shape are already a topic of discussion in at least two other ongoing threads, I would like to flesh this particular issue out a bit further in connection with the famous (some might say infamous) Bergstrom and Ridder rig with which many Hunters are equipped.I don't claim to be an expert rigger, sailmaker or designer but it would seem to me that the combination of a B&R rig with an adjustable backstay makes for an uneasy marriage on the best of days and for a potentially dangerous relationship on the worst. The fractional B&R rig on Rivendel II, our Hunter Legend 43 (hull #1), features a fairly strongly pre-bent mast and is clearly a poor candidate for further bending through tightening of the split backstay attached to the masthead. Attempts at further mast bending through backstay adjustment would be expected to concentrate most forces at the attachment point of the genoa, some 8 ft below the 64ft high masthead. IMHO, this would be an open invitation for trouble. Although Rivendel's design pre-dates the days of the backstayless B&R Hunters, the backstay is relatively lightly built and tensioned. It's main role appears to be to prevent the mast top from whipping around when there is no full main hoisted, as the upper shrouds are quite capable of maintaining the correct amount of mast prebend specified for this particular B&R rig all by themselves. In fact, Rivendel's backstay does not even play an important role in controlling forestay tension, nearly all of which is controlled by the upper and intermediate shrouds, supported by the strongly backswept spreaders of the B&R rig...But what about the masthead-type B&R rigs on many Hunters? Is there any particular reason to believe that mast bend variations large enough to be effective for controlling sail shape, could perhaps pose a threat to the overal integrity of these rigs as well?A tiny bit of fore-and-aft play is unlikely to get most B&R sailors into serious trouble and might even make ex-racers and other sailors addicted to tweeking the backstay adjuster downright happy
. Nonetheless, one should always keep in mind that pulling the masthead down and aft inevitably changes upper shroud tension (and - to a lesser extent - that of the intermediates), because of the strongly backswept spreaders and unusually far aft located chainplates of the B&R rig. So, unless my logic is "all wet", trying to increase mast bend on a B&R rig, (e.g. in order to flatten the main in strong winds) is akin to slackening off the uppers! Not exactly, the recommended course of action in heavy weather, I believe, as this might promote mast pumping and other destructive behavior aloft.Looking forward to your valued insights and comments;Flying Dutchman
