good responses
Mark;For many years, I have been the top trailerable dealer for Hunter Marine and have been close following the designs of the boats more so than anyone else. If it was feasible, structural and within a price range, then an arch would be on the boats. I did see a make shift on a 26 in my travels and not only did it not look good but the hull was not beefed up resulting in damage.Bear in mind that the primary purpose of this boat is a trailerable boat and an arch would simply be in the way. Take for example, the bimin has to be lowered with the legs being unscrewed so the mast when it comes down will not damage the bimini. Placement of an arch would interfer thus not allowing the mast to rest in the mast crutch. If you do put an arch on and decide to engineer a mast crutch on it, I will tell you the center of gravity will shift tremendously and when unpinning the mast, it will come and hit and hurt someone. This has happenned to me in the past.I have tried many things over the years and find that some things work while othere do not.There are many other reasons to substantiate what I am saying but I doubt you will overcome this one if we remain in the fact this is a designed trailerable sailboat. I can tell you that Hunter Marine likes to make money and if it was feasible, an arch would have been on the boat already. Good luck with you design and let us know if you do come up with one.My hangup
