A few more ideas
Ed's right, but I'd add a couple of more things to double check before taking off for cruising:-- The holding tank, if original, should be replaced;-- The water and fuel tanks need to be closely inspected, and you probably should install clean-out ports if they are not there;-- If the stove is original (deisel or alcohol) you will want propane -- expensive but worth it for living aboard.-- If your cruising plan includes lots of anchoring, particularly in Mexico, you'll need better than standard ground tackle, and a dingy with a hard or inflatable bottom. The soft bottoms don't last long on hard beaches, but they are cheaper.-- Save lots of money b yshopping for charts at marine swap meets, or try posting a list of what you need at the marina or yacht club. I just bought several hundred dollars worth of charts for $10 from a sailor who is swallowing the hook.-- Evaluate you power needs, and consider a high output alternator, plus elec panel;s, plus a windvane.-- Your family would appreciate a short wave, for emails and weather and news, and so will you. But someone needs to get thelicense.-- Lerarn to do everything you can. It's fun, saves a ton of money, and there are no boat yards in some very pretty places.. And remember, it's a boat and we all enjoy the work and preparation almost as much as the sailing... Well, almost.Welcome,Sanders LaMontcurrently in Florida
