I have just started the process of fixing the leaking cabin windows in my 1980 C-30. Upon removal of the first window (starboard, forward), I notice that the cabin liner seems to have delaminated from the outer fiberglass shell. I am able to insert a putty knife under the cabin liner and run it all the way around the window opening. There does not appear to be any moisture penetration, even though the window has been leaking. Is this something I should worry about and, if so, what are the recommended solutions?Bob BollerBenicia, CA
