Anyone worked with Trident XHD 1-1/2" sanitation
Rob
hose? I'm putting in an MSD and this stuff is so stiff I can't slip it over the barbed ends of the fittings. I've tried soap and heat and I'm out of ideas. I'm afraid I'm going to break the fittings (pumpout is marlon) trying to get it on. I have the Sanipotty end, the deck fitting and one 90* to do. Thanks for your help.
Dec 2, 1997
9,011
- - LIttle Rock
Are you sure you warmed the hose enough?
It has to be warm enough to soften it, but not hot enough to damage it....which is why I recommend a blow dryer instead of hot water or a heat gun. It does take patience. K-Y works a lot better than dish soap as a lubricant. Smear it liberally on the fitting and the inside of the hose.
7,688
Alden 50 Sarasota, Florida
heat gun
I'm not dumb enough to disagree with Peggie but if you are judicious with the use of a heat gun on a low setting, I've found it to be effective when the blow dryer was not
Tim R.
May 27, 2004
3,626
soak it in boiling water
This will heat the hose more evenly and prevent burning. Tim R.
RobG
Jun 2, 2004
337
Ericson 28 Noank, Ct
OK
I have my stiff hose and some K-Y and...oh wait which forum am I on? Oh, uh-um...thanks gang I'm hoping to skip out of the office this afternoon to give this a try.
Daryl
Forget the hose, use PVC pipe
The overpriced hose may last a few years. PVC pipe will last decades for a small fraction of the cost
