Anyone use 'GreatStuff' ie Foam in the can?
mrbill
Has anyone used Great Stuff, on a boat? (sold at home depot, as insulation foam) -can says waterproof. I have used this stuff for years on varrious home/auto projects, but wonder if it will absorb water, and end up heavy. I need to futher support a vberth bunk, and was thinking this would be good solution, as it is really sticky, has some strength, and is mold-able, (when I put masking tape on outside, after 15-min. added benifit should be additional floattation. So, my question is does this stuff absorb water? any experience? thanx!
Jack Tyler
Here's how to tell...
Bill, I've used Great Stuff to help anchor a holding tank under the cabin sole, in conjunction with wooden braces. If you want to determine how absorbant it is, shoot off a bunch in a closed container (e.g. an old shoe box), let it set, peel off the box, and then weight it in a pail of water for a few days. Lift it out and see how long it weeps. (Using the container keeps the number of cavities to a minimum). You'll have some fissures and crevices that will outflow immediately; if it's still dripping for hours, you'll know it absorbs water. It's billed as closed cell, as I recall. Jack
Bob
A neat little trick
for molding this stuff is to use an ice cube as your "molder". The ice won't stick to that normally stick-to-everything stuff.
Ted
I've used it on my boat . . .
to install styrofoam flotation in my boat. It does not absorb any significant amounts of water, as it is a closed cell foam. I submerged a cured piece of the stuff overnight to test it out. The next day after being submerged, it floated high. I hope this helps, Ted
A
Augie Byllott
Absorbancy of foam in a can
If I wanted to know how absorbent this stuff may be, I'd do this. First, create a cube in a small cardboard box. After the cube has fully cured, peel and weigh it. Next submerge it in water for at least a week. Dry off the outside and then weigh it again. Dividing the latter weight by the original weight would reveal the percentage of water absorption that had occurred.
Mel,
foam as flotation/insulation/rattle supression
I've used the foam for as long as its been available. As far as I can tell(without the weighting for H2O, etc.)it hasn't assorbed any amount. I've used in our Canoe's & Kayaks for added flotation, also used it in the boat/boats to fill space/flotation, and to stop rattles with out any ill effects in the last 20 yrs or so.
