mainsail did an article on reinforcing the through hull fittings and it would be the same process..or you could get some 1/4 thick fiberglass sheeting and cut out some large washers and do that using a good under the water sealant ...don't use butyl tape below the water lineThe thin wood they used as a backing for my speed log and depth sounder transducer in my v-cabin are deteriorating. Has anyone replaced these? Is there some kind of thin plastic I could use instead? Minor issue.
Any chance that Home Depot or Lowes would carry fiberglass sheeting? I made the trek to WM today in Woodbridge, VA and lost 2 hours fighting traffic. Boat is on the hard for bottom painting this week, so if I can grab something handy that helps.mainsail did an article on reinforcing the through hull fittings and it would be the same process..or you could get some 1/4 thick fiberglass sheeting and cut out some large washers and do that using a good under the water sealant ...don't use butyl tape below the water line
what he said or get a chain saw and cut some out of and old derelict boat ...just kidding about the chain saw use a sawzallThe name of the sheeting is G10. Your best bet will be to order it from McMaster-Carr and have them express ship it. They carry G10 as a stock item so you should be able to get it by Tuesday or Wednesday. Defender and Jamestown Distributers also carry it and should be able to ship it to you.
Anyone have a source for the plugs as shown in the second picture?I am thinking of using Aza Board. It is 3/4" thick and I have some scrap. Here is the old one that I got out. It was pretty waterlogged and no longer structurally sound. The other one came out in multiple pieces. It all cleaned up easily.
I am thinking this was a dealer install as it is set up differently from all the others which are painted over and thicker.
To be honest I am the 2nd owner and they have always been there. Since this is Raymarine equipment I suspect you could get them from them.Anyone have a source for the plugs as shown in the second picture?
I'm the third owner of the boat and they went astray before the boat got to me.
