Anyone installed a boom brake on a H30?
Dan_Y
Oct 13, 2008
524
Hunter 36 Hampton
I was looking at the Dutchman 250B boom brake on SBO. Has anyone installed one on a '88 - '94 H30? After setting up a test brake line through the soft vang bale out to the toe rails, it may be a challenge to rig properly. I have used the soft van as a preventer, but want something I can operate from the cockpit.
Thanks,
Dan
Nov 8, 2009
537
Hunter 386LE San Fancisco
Go to Search on this forum and you will find a lot of experience with a Dutchman boom brake. It can be rigged up to operate from the cockpit.
Mar 20, 2012
3,983
a boom brake is not the same as a true preventor, BUT... if the line is tensioned tight, it can be pretty secure....
my point is that a "brake" may be abled to be secured from the vang point as its a passive device and will almost always allow the boom to swing rather than snap in two, but if its to be tensioned down and routinely used as a secure preventor, for safetys sake, it NEEDS to be connected to the end of the boom... this increases the holding power as well as increasing the safety factor many many times over...
on a boat the size of yours and for a brake only, a figure 8 rappelling descender or other type of descender device works great... they are purpose built for as a friction brake but without the sailboat/marine designation.
a device can be had anywhere from $10 to $150, depending on the brand and style.
the way I have mine rigged on my 25 is... I have two strong "pad eye" anchor points 2-3ft forward of the mast and as wide as the deck will allow.... one side has a turning block linked to it....
the brake line is secured to the pad eye on one side of the boat, then back and thru the descender, then forward to and around the block on the opposite side of the boat...then back to a cam cleat at the cabin top....
when the line is pulled tight, it will secure the boom, but when its lightly tensioned, it will allow the boom to gybe gently across without slamming....
its a great setup for running wing-on-wing when you dont feel like keeping a steady eye on the wind vane, or a less observant crew member is at the helm...
on my 34 I dont have a brake, but just an end boom preventor rigged to the forward cleat.... and a deep clew hook that hooks to a bail at the end of the boom...
I think for most of us, the brake is an adequate and quicker-to-use setup, but the preventor is much safer when its actually needed in stronger winds.
Dan_Y
Oct 13, 2008
524
Hunter 36 Hampton
Thanks centerline. I saw the archive is filled with discussion about the Dutchman. My vang attaches only 1/3 of the way back from the mast and the boom end is above the and in the middle of the bimini. According to the Dutchman manual, my installation would be challenging, but I could not seem to find any archive post for my model series boat. Will call them this week even though archive post said they were unresponsive. Worth a shot. The pad eyes forward sound like a good idea. Dan
Mar 20, 2012
3,983
the model of the boat doesnt make a difference when rigging a preventor or boom brake, because the wind and waves dont care... its the geometrics of the rigging that will give the most strength to hold the boom without causing unnecessary burdan on it is what matters..
The dutchman is probably the most popular "sailboat" boom brake you will find.. because its simple and effective. But still, its only a device that works on the principal of friction caused by a line wrapped around a piece of aluminum a few times... im not sure why its so expensive..
Buy the $10 figure 8 device and set up your brake..
Once you get it in place and working then you will know if its not enough friction to satisfy your needs, then you can try the dutchman device... its a $10 gamble that will most likely be perfect for your needs.
