robby
A family gave me a partially built tender. their dad built it in the sixty's and didn't quite get finished. it sat on the basement ceiling until i found it. its about 8' with a flat plywood bottom and square back. it looks like what he did 'hull only' was done marine grade,and correctly. it has a small glass window in the bottom, about 12x14" meant for underwater observation. i couldn't find the plans anywhere. i did find 4 1x4 fir planks which i believe were to make the seats and rub rails there is enough plywood left from the transom to make the v for the front and the 2 knees for the aft corners. i think i can strech the fir enough to make stringers for the seats. it came with a matching trolling motor so i need to make a provision for the battery. does anyone know about west system? should i use fiberglass and if so what thickness and type? should i coat it inside and out? i want the boat white and the fir stained to look like expensive wood, also a blue stripe to match my hunter. also without the battery it will probably get turned over a lot so should i put some foam under the seats. should i coat the wood under the trim? has anyone ever seen this plan before?
