AT 4 ONLY HAS 3 REAL PROBS
THE ATOMIC 4 IS NOT TOO HARD TO FIGURE, IT IS ALMOST 1 OF 3 ISSUESA. FUEL PUMP, THE CAM WEARS AND IT STOPS PUMPING, FIX IS AN ELECTRIC PUMP, PART ABOUT 250.00 INSTALL A PAIN (MAINLY REMOVING OLD ONE, ALSO CHECK THE ANTI SIPHON VALVE ON THE TANK IF YOU HAVE ONE, THEY STICK OPENB. OVERHEATING, A. WATER PUMP, EITHER CAM OR IMPELLER, BEST FIX REPLACE IMPELLER ANNUALLY, IF CAM ITS A PROBLEM. IF IT HAS BEEN OVERHEATING, HEADS WARP, EASY FIX IS 2 OR 3 HEAD GASKETS AND TIGHT IF NOTHING IS CRACKED, ONLY OTHER PROB LIKE THAT IS HEAD GASKET CAUSE HEADS ARE WARPED, SAME FIXC. GAS TANK, THEY GET CRUD IN BOTTOM EVNETUALLY CHOKE FILTER AND KILL ENGINE, TWO FIXES 1 EASY AND MAY WORK 1 TOUGH AND WILL WORKEASY, RUN TANK DOWN VERY LOW, USE HAND PUMP REMOVE GAS AND CRUD FROM BOTTOM, PUT GALLON IN REMOVE AGAIN ETC UNTIL CRUD LESSENED WILL WORK IF TANK NOT TO0D CORODED OR TOO DIRTYTOUGH REPLACE TANK, MAY COME OUT THRU COCKPIT LOCKER BUT MAY NOT, HAVE TO PULL WHEEL STEERING APART TO GET OUT, IF NOT LOCKER CUT COCKPIT FLOOR.OTHER THAN THAT IF YOU CHANGE OIL AND PLUGS AND TUNE ONCE IN A WHILE IT WILL RUN FOREEVER,COMP SUPP TO BE 90+ EACH, HAVE SEEN THEM RUN FINE W ENUF POWER AT 75, IS A BIG ENGINE LOTS OF SURPLUS POWER
