Any reason not to go with 6mm for clew reef line
Jul 7, 2024
60
Catalina 27 Lake Keowee
I will run a reef line through my clew to a jam cleat on the boom near the mast. About 17 feet of line in total, about 8.5 feet when reefed.
Is there any reason not to use 6mm (1/4 inch) for this?
I see recommendations for the 8mm (5/16).
Rational for the larger line is often that it feels easier to hold than 1/4 “. It is up to you.
It is not like there will be excessive force on the line. I would use polyester line. Nylon will be too stretchy.
There is a fair amount of force on the clew when reefed at least as much as with a full sail because the wind speed is higher.
8mm will be easier on the hands.
Jan 7, 2011
5,749
Oday 322 East Chicago, IN
Do you have the reef line run to a winch? Or are you pulling it by hand?
pulling by hand may be easier with a bit larger Line.
Greg
