Hanging the Hammock
I believe one of the sailing mags had a how to article on making a device to wrap around the headsail and support a hammock. Basically you took a heavy duty cloth or leather square, folded it in half by holding the corners, so you have a triangle. You would then put three holes, reinforced with eyelets, two of these would come together when you folded the cloth around the headsail to form one eye to hold the end of the hammock. The other eyelet would be on top of your triangle and hold your patch in place up and down with a jib, genoa, main halyard. The other end of the hammock is secured to the mast.I've not made one yet, but it looked like a good deal. You can make it pretty much any size patch you need to support different weights. I like the idea of distributing the weight on the jib over a larger area, especially if you doing this over a furled jib.
