OK... .Well, it's definitely not the loop. Although I am glad this was brought up for cjfj. Let us know what you find or don't find.
Now this is what is strange. It's been raining here as if there was a tropical storm around. When I went out the other day as it was pouring and
found some other leaks as I mentioned before however (look at the attached pic) The both the A & B areas were bone dry. So I was pretty certain it was the loop.... I started the engine today and nearly to my dismay, there was no leak.
However, Both A and B were wet. The underside of B was dry. Also the storage area under the companionway on top of the engine cover was dry.
As it was pointed out by Dan, Steve and splax the "A" arrow points to the suspicious entry point. So I'll have to dive into the dungeon to further investigate. I would have gone in there today, but I prefer that someone be around just in case something happens down there........ (to be continued)
