Any advice on removing sun protection on genoa
Jul 7, 2024
62
Catalina 27 Lake Keowee
I sail on a lake with low winds, and the sun protection strip on my genoa has a length along the leech that is coming off.
The sail has a wide band of sun material at the foot, and a band of sun material along the leech.
I am thinking of removing all of the sacrificial sun protection material and replacing with a genoa sleave.
I am thinking it is a matter of cutting the stitches to remove the sun material.
Anything to look out for when doing this?
Jun 21, 2004
3,051
Beneteau 343 Slidell, LA
Did that several years ago. To save $, I ripped off the old Dacron sacrificial strip and took it to he sail loft for a sunbrella sacrificial cover. Worse part was pulling the threads from the sail, once the old cove was removed.
Likes: garymalmgren
Jul 7, 2024
62
Do you have a roller furler?
Yes. It is on roller furler.
Our light winds and the weight of the extra material don't mix well. I am thinking a genoa sleeve would be better. I have to take it off and put it on, and it is an additional expense.
If I want to defer the additional expense, I suppose I could sew the portion that is coming off.
May 29, 2018
637
Canel 25 foot Shiogama, japan
RE: Our light winds and the weight of the extra material don't mix well.
Removing the UV protection strip will not make the wind stronger.
Realistically, we are looking at a few ponds of sail weight.
Have you thought of getting hold of a (secondhand) asymmetrical spinnaker/gennaker?
gary
gary
In very light air it’s not as much the weight as the stiffness the sunbrella adds to the sail that disturbs its shape. In order to qualify for a roller furling credit PHRF Chesapeake requires boats to have at least a 4oz woven UV cover on both the leech and foot, so at least in their estimation it makes a difference.
Jun 14, 2010
2,409
You’ll need a spinnaker halyard to raise the sleave/sock. I have one and it’s a PITA. I don't use it. I suggest you sew it or bring it to a sailmaker. Also, the labor will be less costly than a sleave AND likely your sails already are in desperate need of maintenance even beyond that strip. (The reason the strip is coming off is probably UV-“rot“ of the stitching. I’d bet a dinner that the rest of your seams are also very weak. If I’m right you’ll see a self-destruction event in heavy winds sometime soon.).
The boat is a 1985. Is the "heavy" sail original?
Get a new sail made with the new lightweight material. You'll be happier and faster on the water. It can be a Jib, Genoa, or Code 0. Use it for light wind days. I had a friend buy a used Tape Drive sail. He raced his boat with it and loved the sail.
As a data point - I had UV cover stitching start to come undone on a jib that was only 4 season old. We were waiting for a race to start on a particularly windy day when we noticed it. Our sailmaker redid the stitching, and we have not had a problem since. That was 6 years ago and the sail was still serviceable, though a bit blown out, this season.
5,858
Oday 322 East Chicago, IN
I took the sacrificial UV cover off my Genoa to save some money…but I chickened out on trying to sew the new one on…so I took the sail to a local loft. Old sail was pretty bad (about 10 years old I think). Ended up having a new sail made.
Very dirty job, time consuming and easy to rip the sail.
Greg
3,987
Catalina 30 MKIII Chicago
To have my whole sunbrella stitching removed and redone cost $300 and that included maintenance to the rest of the sail as well. Most years I paid about $200 to have both cleaned with minor repairs
I think the OP's issue is performance. I think the sail will perform better without the cover. I crewed on a boat on which a protective sleeve was used so the jib could be left up (Furled). It was a bit of a PITA to raise the sleeve because of the friction of the sleeve on the sail. If it had been my boat I probably would opt to drop the sail and fold or roll it like many racing boats do.
JBP-PA
Apr 29, 2022
711
Jeanneau Tonic 23 Erie, PA
I have the same problem with a light air Genoa I acquired. They had it custom made and used Sunbrella for the UV strip. The Sunbrella is so much heavier it distorts the sail.
I'm going to replace it with a light weight UV protection. Maybe Odyssey or SailRite has a 4oz UV protected Dacron, or Insignia adhesive backed.
8,062
Find a friend or friendly dockmate with a Sailrite or similar, and have a spool of contrasting thread on hand.
Oh, and a case of beer/favorite beverage too.
May 28, 2014
6
Oday 25 Long Island
Why do you consider it a PITA? My sacrificial material has shredded in a few places. Called a local sailmaker, and their over-the-phone estimate to replace was $700. I can get a new sail for 2x that price, or an ATN genoa sleeve for about $350, so I was leaning towards the sleeve. The videos make is seem like a fairly simple process, and I have an extra jib halyard that could be used.
My main concern is that the sleeve might interfere with the furler
Not a problem. It is like you going to the closet and getting an overcoat.
The sleeve goes on when the sail is furled. It is pulled up by its own halyard and zipped around the furled sail as the sleeve is raised. Upon arriving at the boat to head out sailing, you go to the bow, remove, and stow below the genoa sleeve (overcoat) before you untie the docklines.
Likes: sdommer
I think it was the zipper that was a problem. It took 2 people - one to raise the halyard and one to zip.
Jun 21, 2004
3,051
Just realize that the light weight Dacron isn't going to last nearly as long as the sunbrella.
Likes: JBP-PA
