antifouling for props
Jim Sides
What have people found to work well for antifouling for props? I have a CDI feathering prop that is made of a polymer material, I tried wax this past year without good results. thanks.
Bill O'Donovan
Try this
After priming with Intelux yellow (I forgot the number), paint four thin coats of Interlux 2000 base sealant and 2 coats of hard Interlux bottomkote.
J. Tesoriero
Outboard/Outdrive Paint
For the past three years, I have used the outboard/outdrive spray paint available from a number of manufacturers. I clean and sand my prop and shaft, spray on the primer and then the clear antifouling paint. I sail mostly in salt water (New Jersey) and keep the boat in a slip in brackish water (May to October).
