Hi - We have a 1987 vintage Volvo MD30A on our boat ( new to us last year) - that has what I consider a non-standard anti-siphon installed by the PO. The anti-siphon loop is installed NOT in the exhaust, but on the raw water intake. Looking at the exhaust manifold mixing elbow connection into to the exhaust there is no (obvious) place to tee in a hose to install a vented loop in the exhaust, which is probably why the PO installed what he did.
He also installed a manual valve at the top of the loop -- so we have to manually open and close it to allow suction (vent) -- or prevent spray water all over. This I plan on correcting with a proper vent ( like Scots) or a hose.
So here are my questions:
1) Does anyone have experience with an MD30A here and installing an anti-siphon loop in the exhaust? Seems some significant modifications are required.
2) Do we need to ? Does the ant-siphon on the raw water intake (pre - impeller) protect enough to break the siphon and prevent water from entering the engine?
I will not be on the boat until March - so I cannot supply pics - but I can probably find a volvo parts diagram that shows the existing manifold setup.
Thanks, Jim
Thanks, Jim
