Trevor
I decided to replace all the hoses and head in my sanitation system of my 1986 C36. Kinda smelly and I want to get everything shipe-shape for an extended cruise this summer. There are a couple things I've run into that have left me scratching my "head"....1) Did the original plumbing from Catalina not include anti-siphon loops for the intake OR discharge hoses? There is such a loop for the sink/shower drain through-hull, but not for the head? Shouldn't there be a 1/4" anti-siphon loop between the pump handle on the head and the bowl? What about the discharge for the overboard through-hull? There is a "Y" valve set to the holding tank, but there is also hose to the outboard discharge through-hull and a "Y" valve... how can this work without a 1 1/2" anti-syphon loop? I plan on cruising offshore and would like this option. 2) Re: anti-siphon loops, does the discharge one need to be placed downstream of the "Y" valve by the through hull? Can the anti-siphon loop on the intake be before the toilet pump handle or must it be between the handle pump and the bowl? I'd like to set these up as inconspicuous as possible.3) Last one, honest. I bought a new head and "Y" valve by Jabsco. Seems the 1 1/2" fittings are a little small, causing leaks even with double clamps. I've been told to add electrical tape to the fittings to make the tighter fit for the hoses. Shouldn't the fitting be standard? Thanks in advance for any help...TrevorS/V Dunoon, #640Seattle, WA
