G
Gary Wyngarden
1. With 2056 test results in, 74% of the test takers got this right. The key to the right answer is the term motorsailing. While the general rule is that boats sailing on a port tack are the give way vessel to boats sailing on a starboard tack, when a sailboat has its motor on and in gear, it becomes a power boat. And unless the powerboat is in a restricted channel or restricted in it’s ability to maneuver, engaged in fishing, not under command etc., the power boat is the give way vessel to the sailboat. Source is collregs or any sailing text.2. 59% got this right. The traveller should be eased to leeward to reduce heel and weather helm. Tensioning the outhaul will flatten and thus depower the main. Easing the mainsheet will spill wind and taking in a reef will also reduce the power of the main. Source is Dennis Conner’s Sail Like a Champion.3. Only 18% of test takers got this one right. The source is NOAA Chart Number 1 which is a recommended reference for every sailor. The symbol deals with rocks that play “peek a boo” and we have a bunch of them up here in the San Juans. Our tidal range can be as much as 12 feet or more, and a rock that uncovers on a three foot tide will be hidden from view on a six foot tide and grab your keel. NOAA charts generally report depths in fathoms but elevations in feet. Since the rock on the test is three feet above a zero tide (aka chart datum) it is technically an elevation not a depth.4. 90% of test takers got this right. Obviously your raw water system is not always the problem on overheating, but Nigel Calder says it’s the place to start. Seaweed in the water intake is a common problem in our home waters. Check the raw water strainer for blockage. Ditto the through hull and any connecting hoses. Maybe a blown raw water impeller. After that it’s on to plan B. Source is Nigel Calder’s Marine Diesel Engines.5. 83% of test takers got this right. An important thing to note is that the other options on the test could be deadly. My understanding is that the critical thing is to keep warm blood in the body’s core for the essential organs. Giving the victim alcohol or caffeinated beverages will increase circulation to the extremities taking warm blood away from vital organs. A serious hypothermia victim is not able to rewarm himself or herself. Source is The Annapolis Book of Sailing by John Rousmaniere used as a text in American Sailing Association advanced courses.6. Only 40% of test takers got the anchor rode question right. If your transducer is two feet below the water line when your unadjusted depth sounder is reading 15 feet, the water is really 17 feet deep. The tide comes in 5 feet which brings us up to 22. Add 4 more feet for your freeboard to the bow roller and you’re up to 26. Multiply times 7 and you’ve got the answer of 182 feet. As many have commented, this isn’t always realistic due to swing room concerns, but it’s what the sailing texts recommend. Source again is Rousmaniere’s Annapolis Book of Seamanship.7. Only 18% of test taker’s got the fog horn question right. For a boat under sail, the proper signal is one long blast followed by two short blasts every two minutes. Source Rousmaniere, Annapolis Book of Seamanship.8. 75% got the lights at night question correct. The only correct answer offered was option “c” with a red port sidelight, a green starboard sidelight and a white sternlight. As some have pointed out a tricolor light at the top of the mast may be an alternative in certain circumstances. Add a steaming light if you are under power. Source again is Rousmaniere.9. 45% got the green over red buoy question right. Mike Pyzel writes in Coastal Navigation, the official American Sailing Association Coastal Navigation Manual: “Red over green (or green over red) horizontal bands mark junctions in the channel. The color of the TOP band indicates the side you should leave the buoy on in order to follow the main channel. If the top band is red, leave the buoy to your right when returning to follow the main channel.”10. Only 35% got the telltales question right. Dennis Conner says “With the sails properly trimmed the windward telltales on the headsail should flick every other second or every two seconds.” I’m not sure what Russell Coutts would say about that! Source is Dennis’ book, Sail Like a Champion.Hope you enjoyed the quiz and maybe learned something. Based on the response, we’ll plan to do more.Gary Wyngarden
