video and rudder storage
patrickfarley - Take second look at your trailer with the boat on it. Look at all the room under the trailer bunks to mount crutches, ginpoles, a-frames, ladders, extensions and with all of these there still should be plenty of room for a rudder. Get it out of the cabin, cockpit, trunk or pickup bed, make a cradle on the trailer to transport the rudder around.
The video
The extra large A-frame used in the video would have to be used if the mast plate and mast is not hinged like used on all popular trailersailors. I think it would be easier for that fellow if he converted his mast attachment setup to a hinged configuration and then use a standard size A-frame to swing it into position.
He’s assembling a tall A-frame, standing it up over the cabin roof, attaching 4 stays to the boat to keep the frame from falling sideways and front to back. Then he has to disconnect all the mast stays to lift the mast vertical a couple inches . I’m thinking the time it takes to do this once would be enough time to convert the maststep and then he would be looking at just a little more time and effort it takes all of us to swing our mast up or down.
