Another traveler question
E
Ed
How important, unimportant, is a traveler if you have a self furling main. This would be on a 290 or a 320.
L
Len Fagan
Traveler
I am a bit cofused with your question. The reason that the mainsheet traveler is on board is to control the location of the main boom. This alows you to adjust leech tension. The furled main reacts to this as well as a conventional main. I own a 450 with furled main and use the traveler primarily in heavy weather to control heel (depower the main) Len Fagan
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
Question and answer.
What IS a 'self-furling' main? Do you mean the thing which rolls up into the mast like a window-shade? Assuming you do, I would contend that a traveller to assist with maintaining sail shape is even MORE important than it is on a proper boom-footed set-up, in which a traveller is already crucial. Stowaway sails are NOTORIOUS for poor sail shape as the loose foot allows far too much belly in the sail (and no control over how much). The whole point of the track on the boom is to keep the sail panel flat. If belly is needed to assist draught through the sail (as in light air) it can be added via the outhaul and other stuff. The traveller is a MUST for loose-footed set-ups, and it's got to be mounted to pull as closely to vertical and as close to the END of the boom as possible, for leverage in keeping the boom end DOWN. I would also seriously consider uprating the line size for the outhaul (tack line) if possible. Even so I'm not sure it will ever be as good as with a boom-footed rig. And as soon as you roll that main in even part of the way the sail shape will go all to h*ll anyway. You may take this as you like it, but I will caution the debaters that as soon as you start worrying about raising the boom end to keep the bimini top up or to be able to propose toasts to your cockpit parties under way, you are probably not as interested in having a flat main for performance anyway-- and so why waste your money? JC 2
K
Kenneth Pfaff
Useful in heavy air
I have a 2001 290 with a roller furler main and have the traverler installed on the top of the arch. We use it when the wind kicks up to de-power the main and reduce the heeling of the boat. It is very easy to use as there is a line on either side of the boat along with a Harken cam cleat.
Ralph Johnstone
The Greatest regret of My Life .................
......... is not ordering a factory installed traveller from the factory for our 1999 H310. It too has a self furling main. I WILL eventually do it myself but probably at considerably more cost. Regards, s/v Island Hunter
Don
Ralph..if that's your greatest regret in life..
You've had a pretty darn good life! Be thankful and enjoy the boat.
