I didn't want to hijack the other thread on this topic. I'd like to explore the idea of building a passive geothermal AC system for a boat. (should it be called aqua-thermal?)
If you are unfamiliar with geothermal.. here is a link
and a schematic for a house.
My first draft idea would be to use something similar to a solar water heater used to heat a pool as a heat exchanger. This would have the advantage of beeing flexible and able to roll it up and stow it when not at anchor...
Toss it overboard with quick disconnects to a closed system in the cabin when at anchor.
Then inside the cabin have a second one of these...
... that you blow a fan through to cool the air. A low amp pump to move the fluid between the two completes the system. I guess the one that goes overboard should be white in color to help deflect the heat. All that is left is to design a way to collect the condensation on the inboard side (maybe doubles as a water maker).
I see this as a hybrid between true geothermal and a split system AC unit.
Okay all you engineers.... how do we make this work and not take up too much space and keep the ease of use (portable)... all at the same time.
Building a New Home? Consider Adding Passive Geothermal Energy in Your Construction Plans - 21st Century Tech Blog
August 21, 2018 – First-time guest blogger, Arthur Smith, today is writing about an energy source most developers of new subdivisions and buildings overlook. Smith describes himself as the main editor of LEDwatcher.com, a website that tracks the latest technology innovations in LED lighting...
www.21stcentech.com
