I'm planning to make the switch to lithium. I'd like to run the general outline of my plan by the collected wisdom of the forum.... My plan is to have a lead acid start battery, separated from the house battery switch. As I understand it, the charge line from the alternator, and the battery cable to the starter, run thru the common pole on the battery switch. My plan is to disconnect both from the battery switch, and run them direct to the lead acid start battery. The alternator wouldn't charge the lithium bank at all, I will decide on a DC/DC charger later if needed. For now the lithium bank will be charged by solar and the installed battery charger, both are compatible with lithium, the start battery will only charge via the alternator. Of course I will be fusing the lithium bank appropriately. Does anyone see any issues with my plan? Anything else I should be thinking about? TIA
