Troubleshooting
I had a problem with my fuel gauge and voltage meter last year. I checked everything out and finally decided the gauges were off so I replaced them and all has been fine. Here are some notes that I wrote down from that.
The fuel gauges are Teleflex; in the West Marine Catalog is a "Teleflex" 'Universal electric fuel gage and sending unit", sending unit Model #547406 TELEF#90424P which costs $29.99. To order a new gauge, contact Lonnie at Seaward (562-699-7997 x213),
Lonnie believes there are far too many change-outs that are simply the result of faulty wiring. There are only three parts for the fuel gauge system.
1. The gauge itself (less likely to fail)
2. The wiring between the gauge and fuel tank (more likely to fail)
3. The tank sender/float assembly (more likely to fail)
To access the fuel tank sending unit you need to remove it from the top of the tank where there is a round plate with 5 screws. Sender is attached to the bottom side of this plate. You need a stubby Phillips screwdriver as there is not much clearance above the tank. The gauge is a volt/ohm meter and the sender/float assembly is a variable resistor on a pivot style float. If it is reading full continuously the gauge is bad or, most probably, there is a short in the wire from tank to gauge.
• When tank is empty, float arm hangs almost straight down
• When tank is full, float arm is floating horizontally and touches the top of the tank
• The arm must have nearly a full 90 degree unobstructed swing
• You can loosen the set screw(s) on the sender and rotate the sender 90°
• Ensure sending unit is oriented correctly as the float rotates and may hit the side of the tank and not read correctly
