Another Fuel Gauge Issue
7
Catalina 30 TR Austin (Lake Travis)
I have a fuel gauge that used to work fine. One day it started reading -E (negative empty) as soon as I turn on the ignition. With the ignition off, the gauge reads E just like a car gauge would show.
I have pulled the gauge from the top of the tank and moved the float to the full position, and, it still shows -E.
This diesel engine and fuel tank is new for me. Where do I start looking for the fix? Is it electrical or mechanical?
Thanks for the in-put.
Rocknoids
Jan 4, 2006
6,600
If It Goes Backwards ......................................
................... just maybe it's an electrical problem.
If you are sure you haven't changed any wiring prior to the problem rearing its ugly head, try checking if there is any voltage difference between your battery neg. terminal and the ground right at your meter. OR just run a wire from your meter ground terminal right to your battery neg. with a piece of scrap wire.
Please let us know what happens.
Feb 10, 2004
3,967
Hunter 40.5 Warwick, RI
Rocknoids,
I think the problem is that the sender wire from the sender to the gauge input is open. Attached is a document that describes your failure mode and tells you how to T/S the gauge and sender.
To the best of my knowledge, all of these gauges work the same way regardless of the manufacturer. These documents were written by Teleflex.
CYA disclaimer: YMMV
11,677
I always start with the sender because the test is easy & quick. Set your Ohm meter to resistance/ Ω and connect red to the center stud and black the flange of the sender. This generally works better with an analog volt meter but digital ones work too. You should see readings that are close to 240 Ω when empty, about 100 Ω at half and 33 Ω at full.
If you see these numbers the sender is working correctly. If you have the sender out move the float up and down manually and watch your Ohm meter for any drop outs.
You can then test the continuity of the feed wires. It is often a failed sender but can also be a bad or corroded connection. The wires to the sender from the gauge are not carrying voltage, they read resistance, so you will not measure "12V" at the sender end. The gauges also can go bad but I find the senders go bad more often.
Jun 6, 2006
6,990
You have the ground wire from the sender to the gauge picking up 12 volts somewhere. The gauge is just an ohm meter (sender is just a variable resistor attached to a float) with a “funny face” that reads the tank level instead of ohms and when you try to get it to measure voltage it goes "full scale" In this case full scale negative so the ground is getting voltage.
Check the wires behind the panel by turning the motor on and wiggling them to see if the gauge starts reading correctly. if that does not yield something trace the wire to the sender looking for a bear spot. I'm thinking it has to be near the panel as the rest of the wire run probably does not have any power wires near it to supply the 12 volts.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
My fuel gauge has a bit of a different issue. It seems to read fine and read correctly, EXCEPT, it reads backwards so when at full it shows empty and at empty shows full and everything in between is reversed. Any suggestions? It has worked this way for as long as we have owned the boat. The PO must have lived with it. I have checked and rechecked all of the wiring and it appears to be correct. Chuck
Feb 6, 1998
11,677
Chuck,
Is it a VDO gauge by any chance? I had that same issue with a VDO. After all the trouble shooting steps I replaced it with a Teleflex gauge and problem solved. The VDO should have been the same as the Teleflex but was not for some reason and read backwards... Never seen this any other time except with one VDO gauge..???
Chuck, you could do as Maine Sail suggests.
Or:
1. leave it just as it is - every boat needs an oddity (other than like mine, which is the skipper!)
2. disconnect it completely and tell the next owner to use engine hours to measure fuel consumption (our fuel gauge hasn't worked since 1999 and i haven't run out of fuel yet)
Always somethin', isn't it? :)
Jun 6, 2006
6,990
VDO wants you to by their senders too. They wire it backward so full is high resistance and empty is low resistance. The rest of the free world has full as low and empty as high.
You could take the unit out and move the resistor ground to the gauge terminal and the gauge terminal to the ground. Or if it has two wires just reverse them. I don't think the latter is going to do anything but with VDO you never know. Also check for a third terminal on the sender. If it has three then you are in luck. One set will read high-low, another will read low-high and the remaining will either not show any change or read twice the resistance value. worth a look.
Jan 3, 2009
821
The gauge says Kybor/Medallion on the face. I made a label with a label maker with an E and an F and stuck them on the gauge to show it correctly. Not at the top of my priorities right now so as long as I can see how much fuel I have in the tank, oh well. Chuck
Dec 2, 1999
15,184
New ones are not that expensive ($40 for a Wema). You should get your electrical checked out before you decide to replace the sender.
http://www.wemausa.com/
check out the 25% discount at check out if you need to replace the unit.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
you can get them from Bestfab in FL...go to there web site and then go to there ebay store on there site...i got mine from them for my water tank and my fuel tank ...both for $25.00 each and the have fuel pick up tubes as well for around 6 to 7 dollars ..and there shipping and responce time is great
regards
woody
Feb 6, 1998
11,677
regards
woody
I believe your gracious host also sells WEMA sending units. Personally I prefer the mechanical senders with the magnetic capsule that reads the tank level. They seemingly last forever...
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
thanks for the info...when i pulled them up i got a bad url address on the pages.....had no idea that they sold these.....oh well next time i will be able to recomend them as well....
regards
woody
Sep 30, 2008
7
Thanks! These are great thoughts and suggestions. I will look into the problem after Christmas and New Years. I really appreciate the help.
