another damn leak found
Apr 19, 2011
456
Hunter 31 Seattle
so this one is coming out of the port side light fixture. Water is running down the support beam. I used to have this problem before I fixed the compression post and I thought I fixed it last time when the mast was down and we re caulked the wires coming into the boat. We even put it on a 180 degree s curve like in the dorad vents. I'm trying to think of what other place water could be coming from.
Thanks,
Jared
Mar 6, 2012
357
Hunter H33 (limited edition cabin top) Bayou Chico
hardware, also if its coming from the cabin top it could be from anywhere on the deck, likely higher or on the same side, but all the hardware is suspect.
Oct 29, 2005
2,362
You need to get that little dutch boy as crew. He'll plug those pesky leaks with his fingers. ;)
