Another bottom paint ?????????
grigs
Jan 2, 2007
37
Catalina 25 East Greenwich
Bought our boat last season while it was on the hard. Former owner said the boat had bottom paint put on the previous season so it was one full season ( May to Oct) Rhode Island (Salt) . Bottom looked like new. He said he would try to look for the type of paint and get back to me, but boat went in the water and made the deal. Never heard from him again. Past season the boat was back in for Aug to Oct. Hauled it out and power washed it.Looks the same as when it went in. ( like New ) ????? Should I scuff and paint, and does it matter that I don't know what kind of ablative paint he used?? Thanks Grigs
Aug 26, 2005
49
ERICSON 34 Mattapoisett
Interlux Micron
Talk to the people at Johnson Wholesale. They were helpful to us last year. We hope to get 3 seasons (Buzzards Bay).
May 11, 2005
3,431
Seidelman S37 Slidell, La.
You can sand very lightly
You can sand it very lightly in a small area and it will be obvious whether it has an ablative or a hard bottom paint on it. The way I understand the bottom paint is you can put an ablative over a hard paint, but not hard over an ablative. But check the mfgs. specs. I think most of the paints are compatible with others of the same type.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Just painted my hull for the lower Hudson (salt)
water environment and launched. I have been using an ablative paint that slowly flakes off in the salt environment for a few years and it always comes out looking great after a power washing. I put on 3 new coats of the same paint but that is just me. My boat once came out with a nice beard several years ago because of an inadequate job I had done on it with a different paint that shall remain nameless so certain members of this forum (Waffle) do not get upset (VC-17 - better in freshwater). If your boat has an ablative or soft hull paint on it then if you rub it with a dry or wet white rag and a good bit of color comes off on the rag then it is probably a soft or ablative paint. This paint seems to work well in salt water, is recommended by Practical Sailor among others and was on sale at WM (west marine) for well under $100/gal earlier this spring (WM CPP Ablative - $35 mail in rebate, which I have not yet received - final cost nearly $60/gal). If your hull has paint chips forming that will easily pop off then you have a hard paint (which I doubt if your PO had any salt in his blood) and I have little to say about that except that I hope you like sanding and scraping sloping surfaces. If the hull looks good, try to get away with just a mild hand sanding with say 120 - 150 grit paper. It is a good idea to lightly sand the entire underwater surface before you do the wipe down. I always wipe my hull down with Interlux thinner #216 but some say you should use the #202 (fiberglass solvent - inhaled too much of this stuff, cant remember the #) with a copious amount of rags to get all the stuff that is about ready to fall off completely off the hull, before I start painting (put masking tape on water line before all of this of course). 1 gallon of anti-fouling paint covers the hull of 27' Tartan (which has a rather long keel) almost twice so for your 25 footer that would be an easy 2 coats per gallon. You might be able to get away with one more season without doing anything. As soon as the hull comes up with mussels and starfish on it and a seaweed beard you will want to have the insurance of another coat of hull paint. I would recommend buying a gallon of hull paint and either putting one coat on before you launch this season, while saving the last half gallon for the next coat, or, just giving your hull 2 coats and a good paint job that will hopefully last a good while in salt water. Your hull is after all the part of your boat that you want to keep water out of by any means available. I like doing the hull job on my old 1967 boat myself as I get to see every square inch of her under water line up close and personal. Am I being anal about this? If I were Huck Finn I would want to construct a raft that floated with me and Tom and supplies and was safe. But I am not Huck Finn and I have a fiberglass boat now and am resigned to the fact that I do have to paint the bottom nearly annually to keep it from becoming part of the underwater flora and fauna. Good luck getting her in the water.
grigs
Jan 2, 2007
37
No chips
There are no chips on the bottom paint at all, it really does look like it was just done. It is a kind of dull finish, and when you rub your hand over it, it does leave a bit of a powder coat on it. I don't mind doing the light sanding that you are recommending. I think my bigger fear is having a bad reaction of two diff. paints, but as nice and easy says.....Cheak with manf. Thanks All
