Another anchor (rode) thread
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
I need to procure a second rode as a spare and also for use with a second anchor if necessary. So, I’m looking at 3 strand or 8 plaitt to be used in the PNW. Main anchor has 100’ of chain with 200’ of 3 strand and secondary has ~ 25’ of chain. Anchorages can be a little deep at times with unknown bottom conditions. Boat has a vertical electric windlass with drum and gypsy. So, I'd like to hear opinions on both types of rode! Tnx!
Mark. I have 105' of chain and 250' 8 plaitt nylon rode. The 8plaitt was selected based on the smooth run over the gypsy and the nature of it lying compact in the anchor well. I have experienced no hockles as I did with 3 strand. It has held well in 45knt winds at anchor in Port Ludlow where I had 5:1 scope. The boat danced a lot but within her space.
Likes: jon hansen
Jul 27, 2011
5,144
Bavaria 38E Alamitos Bay
The “rode pundits” I’ve read say that 3-strand (twisted rope) has better elastic (stretch) capacity than 8-plait and is easier to splice oneself, e.g., rope chain splice. Equally strong as 8-plait but not as easy to handle or stow as 8-plait. Can jam windlass whereas 8-plait generally does not. I’ve always used 3-strand so cannot say comparatively which to prefer in use. But I do prefer a rope braid that I can splice myself, on the boat, as needed, etc. Some complain about how 3-strand stiffens with age and use. I wash and soak my periodically in the Woolite water bath; helps some.
Likes: Rick D
Read the manual for the windlass. Some windlasses advise against 8 plait. If the windlass has a capstan as well as a gypsy, then 8-plait will work. The advantage to 8 plait is it collapses in to a smaller pile than 3-strand so it takes up less space.
We have ~150' of chain with j~150' of 8 plait.
Dec 25, 2000
5,950
Hi Mark. Have had for years 50' of chain and 150' of three strand, plus another set of the same for those very rare times where needed. Over the years I tend to drop at 20' mid tide with a four/five scope in normal weather conditions and will increase to seven or eight in a blow. Prefer three strand due to its splicing ease as well as its elasticity.
Likes: Kings Gambit
Jun 14, 2010
2,410
@Kings Gambit I’ve spliced my own 8-plait and it’s not difficult. There are plenty of online instructions available. It’s better than 3 strand in every way except chafe and snags.
It’s more likely to catch fibers on rough surfaces because of the cross weave at the surface, vs. 3 strand that has linear fibers along the surface. Same issue with braided dock lines vs. 3-strand.
We have chain and 3 strand. The 3 strand has never given us any trouble (although our anchor locker is quite large). It runs through the windlass without any problems (except for where the chain/rope splice is) and has not hockled at all.
3,841
Corsair F-24 MK I Deale, MD
3-strand is about 30% more abrasion resistant, based on side-by-side testing on rock. For me that settles it. I've never had a rope stiffen enough to bother me, though I'm sure that depends on the rope manufacture and how often it is washed or rinsed.
With a windlass, I liked having enough chain that I didn't need to pass the splice most days. Elasticity comes from the snubber (bridle).
JBP-PA
Apr 29, 2022
711
Jeanneau Tonic 23 Erie, PA
I switched from 3 strand to plait and I love it. Much easier on bare hands (I don't have a windlass). Stows easier and takes up a lot less room. I have 300 feet in the same space of 100ft of the old 3 strand. Snags and abrasion are an issue, I use chafe protection on the bow roller. Yale claims it has better shock absorption than 3 strand.
