I took my suspect alternator off my Perkins Prima 50 to have it bench tested. It is not putting out at all. The tech said it was a Lucus, and only about 40-50 amp. I have two 4d gel cells in my house bank, and he said an alternator was not designed to charge this much battery. (400 amp plus starter battery) I know there are lots of you sailers out there who cruise to places where you have to depend on the alternator to bring the batteries back up. Is therea an alternator I can replace my current one with that will do the job? If a lot bigger, in the 100 plus amp class, do the wires that go to the starter and to the battery need to be up-sized?
