Since the sandblaster is coming to me, time is less an issue, thanks!
That's the best possible scenario... acetone rinse and hit with epoxy right away. Some tips I learned from my experience;
- I tried laying the keel flat on two heavy saw bucks, you're better off hanging the keel from a cherry picker if you can, or just from anything you have; that way you can get at both sides.
- Be careful with the epoxy, I had a batch kick off and boil in the plastic contained because I didn't work fast enough. Pro tip - pour it into a flat paint roller tray after mixing, it won't warm up too fast.
- using the fast cure hardener is fine, just use the shallow roller pan and roll it quick. If someone talks you into using a slow cure epoxy then it will be harder to 'hot coat'.
- I found that 10 to 12 pumps of resin was what it took to completely roll one side. Start with 8 pumps and se how far that goes.
- Buy just two quality epoxy rollers and some cheap chip brushes, you only need them for the first two coats. Everything after that is done with spreaders and the pink Bondo Brand spreaders from Home Depot are cheap and actually very good.
- Your first two coats are the most important, these are the 'sealing' coats and need to be applied un-thickened. You want to 'hot-coat' them, meaning roll the first coat and when it 'kicks off' (becomes tacky but not cured) then roll on the second coat. This gives a chemical bond which is stronger than a mechanical bond and you don't have to sand between coats!
- The third coat you also want to 'hot coat'. You can allow the second coat to get firm, so basically your fingernail can press into it but don't let it sit overnight. This 3rd coat you want to add some filler like colloidal silica or micro fibers (not low density fairing filler). Use the bondo spreader to apply to damaged areas, low spots, holes, etc. Its ok to work in small batches as long as you are in the 'hot coat' window. Work the bondo spreader to get the smoothest surface you can but it need not be perfect.
- It helps to add grey or white tint to the epoxy, I prefer grey. The bottle is $16 but goes a long way. It adds the element of a visual indicator so when you start fairing you don't sand off too much material.
At this point you've applied two coats of un-thickened resin which is your true epoxy 'barrier coat' that is waterproof, plus the thickened epoxy to fill and smooth any rough areas or damage. You've 'hot coated' giving you a stronger chemical bond and avoided sanding between coats. Let this cure at least overnight, but now you can let it sit for as long as you like before you get back to it with no worries about rust. When you do get to the next step, sand with 80 grit on a belt sander or orbital to get the rough shape and then you can apply low density fairing filler.
