Anode size
Jan 10, 2018
264
Beneteau 331 Halifax
Hello all,
I am having a problem getting a 25mm anode. can I use a 1" one instead? The difference does not look material.
What do you think?
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Hello all,
What do you think?
A 25mm anode can be made to fit on a 1" shaft but a 1" anode is too big to use on a 25mm shaft. As mentioned previously- go to boatzincs.com
Jan 10, 2018
264
Yes, I did, thanks. Afetr some pounding with 2 hammers and tightening over a day, I still did not get the two pieces quite together, this with a 25mm donut.
