Anode Rods For Aluminum Water Tanks
sawimp
Aug 18, 2010
14
Hunter Legend 43 Londontowne
Considering the eventual corrosive fate of the aluminum water tanks in our boats, has anyone ever installed a sacrificial anode rod into the tank to eliminate the corrosion? Is there any sacrificial metal that would be more sacrificial than aluminum??
ALNims
Jul 31, 2014
208
Hunter 356 Huis Ten Bosch Marina, Sasebo, Japan
Maybe you could install a water bladder inside the aluminum tank which would act as a liner. The wall structure of the tank would support the bladder.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
why not put the anode on the outside just like you do on the prop shaft
ALNims
Jul 31, 2014
208
Can you explain how to do this via the 1/2" +- dia. fittings?
I doubt seriously that you could stuff a bladder through 1/2" diameter fitting. Depending on how much access to the tank top, you could cut a hole and put it through there. Another possibility would be to cut an access and coat the tank interior and then make a bolt on tank cover with a gasket.
