anode placement
Oct 15, 2015
206
Hi all, I have been meaning to ask this question for some time and have just gotten around to it. I have noticed on my Vega there are two anodes. One on the prop shaft and the other located internal on my Yanmar. This does not seem like enough considering other boats in my area have more attached. I have seen many sailboats with anodes attached to the rudder to prevent shaft corrosion. Is the Vega supposed to have this option, or is it not needed. Has anybody attached one with good results? Do you have anodes attached in other areas? Now would be the time to find out while my boat is on the trailer. Thanks...
Jan 28, 2001
694
Hi Tim, Are you sure your Yanmar has a anode? My 2GM doesn't by design and I think you said you have a 1GM? I do need to replace the bottom "peg" on my rudder blade as it is looking somewhat pitted. Think of is as a hinge pin that sits on the bronze shoe
and the rudder sits on top of. It I can't think of any way to attach a zinc to it though. The rudder shaft where it goes into the boat has always looked fine. As far as other zincs go most folks also have one on the prop nut as well as the shaft.
WaltFrom: AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of alaskaflyfish@... [AlbinVega] AlbinVega@yahoogroups.com
Sent: Monday, September 12, 2016 1:21 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] anode placement
Hi all,
May 30, 2006
1,075
anodes are really important if your boat sits in the water all the time.
I believe there are electrical currents from other boats, chargers, and dock electrical wiring that does this.
Also, I think it matters if your boat is plugged in to the dock power... this makes it worse.
But its always good to be safe. Mine only has them on the shaft and prop.
There also may be one in your heat exchanger in the motor. It will likely be like a plug. Where you screw it in. The Beta has that.. Look for it in the yanmar.
groundhog
Oct 15, 2015
206
Hi Walt, The Yanmar 1GM10 has a small anode on the port side upper cylinder head that lay inside the water jacket that is cooled by raw water. My prop does not have a zinc nut. Its a 3 blade 12RH10. I dont know the manufacturer. Sounds like your gudgeon and pintle are starting to corrode. I wonder what the inside of the rudder looks like. Mine look OK for now but a zinc sure would be helpful in preventative maintenance. I wonder if anybody has found a way to attach an anode. From: "walt judy brown allore bestvega@... [AlbinVega]" AlbinVega@yahoogroups.com To: "AlbinVega@yahoogroups.com" AlbinVega@yahoogroups.com Sent: Sunday, September 11, 2016 5:43 PM Subject: Re: [AlbinVega] anode placement
Hi all,
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855 --
#ygrps-yiv-930114292yiv5170261855ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mkp #ygrps-yiv-930114292yiv5170261855hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mkp #ygrps-yiv-930114292yiv5170261855ads {
margin-bottom:10px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mkp .ygrps-yiv-930114292yiv5170261855ad {
padding:0 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mkp .ygrps-yiv-930114292yiv5170261855ad p {
margin:0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mkp .ygrps-yiv-930114292yiv5170261855ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-sponsor #ygrps-yiv-930114292yiv5170261855ygrp-lc {
font-family:Arial;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-sponsor #ygrps-yiv-930114292yiv5170261855ygrp-lc #ygrps-yiv-930114292yiv5170261855hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-sponsor #ygrps-yiv-930114292yiv5170261855ygrp-lc .ygrps-yiv-930114292yiv5170261855ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855activity span {
font-weight:700;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855activity span span {
color:#ff7900;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855activity span .ygrps-yiv-930114292yiv5170261855underline {
text-decoration:underline;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855attach div a {
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855attach img {
border:none;padding-right:5px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855attach label a {
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855bold a {
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 dd.ygrps-yiv-930114292yiv5170261855last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 dd.ygrps-yiv-930114292yiv5170261855last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 dd.ygrps-yiv-930114292yiv5170261855last p span.ygrps-yiv-930114292yiv5170261855yshortcuts {
margin-right:0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855attach-table div div a {
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855attach-table {
width:400px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855file-title a, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855file-title a:active, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855file-title a:hover, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855file-title a:visited {
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855photo-title a, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855photo-title a:active, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855photo-title a:hover, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div.ygrps-yiv-930114292yiv5170261855photo-title a:visited {
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 div#ygrps-yiv-930114292yiv5170261855ygrp-mlmsg #ygrps-yiv-930114292yiv5170261855ygrp-msg p a span.ygrps-yiv-930114292yiv5170261855yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855green {
color:#628c2a;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 o {
font-size:0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855photos div {
float:left;width:72px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855reco-category {
font-size:77%;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855reco-desc {
font-size:77%;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 .ygrps-yiv-930114292yiv5170261855replbq {
margin:4px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mlmsg select, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 input, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mlmsg pre, #ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 code {
font:115% monospace;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-mlmsg #ygrps-yiv-930114292yiv5170261855logo {
padding-bottom:10px;}#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-msg p#ygrps-yiv-930114292yiv5170261855attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-reco #ygrps-yiv-930114292yiv5170261855reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-sponsor #ygrps-yiv-930114292yiv5170261855ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-sponsor #ygrps-yiv-930114292yiv5170261855ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-sponsor #ygrps-yiv-930114292yiv5170261855ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-text {
font-family:Georgia;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-text tt {
font-size:120%;}
#ygrps-yiv-930114292 #ygrps-yiv-930114292yiv5170261855 #ygrps-yiv-930114292yiv5170261855ygrp-vital ul li:last-child {
border-right:none !important;}
May 30, 2006
1,075
I think the situation is when you are in the water and all your neighboors are plugged in to shore power. And you are also plugged into shore power. Everybodys electricity goes all the way down the dock on the wires, and back up. Supply and return. It ends up that everybodys boat is an electrical contact in the water. And everybody has a slightly diferent voltage. This makes a big giant battery out of the whole marina. Each boat having a littile tiny charge flowing between boats. Carrying minerals from your metal to and fro. Dont plug your boat in. Get yourself a solar panel like i did. and a charge controller.
groundhog
