Sail Power was written ...
before any aerodynamicist (ie.: A.Gentry) explained how sails 'actually' worked ..... NOT the way you learned it in a USA high school, most sailing instructions books, etc. etc. which is TOTALLY WRONG. Even the Wright brothers would totally refute what is commonly believed/taught to be the mechanism of lift on a sail/wing. The "Slot effect" is totally wrong, the airstream on the lee side of the sail doesnt have to 'go faster' (think of a sail with essentially NO THICKNESS). etc, etc. etc. etc. !!!!!!!!!!!!! Lift is simply a function of viscosity (the 'friction characteristics of a fluid' ) and the fluid speed across a 'shape'. Hell, sails 'are' curved flat plates with NO thickness. Like most 'technical/scientific' topics, the stuff taught in most USA highschools remains simply uninformed authoritarian BS (and gives credence of why the US educational system is so very poor for technical/science subjects - ranks at the very bottom in comparison to most other nations). The published work by Arvel Gentry is the 'source' of most modern 'sail' shaping/trimming/setting books. Even the great Marchaj (famous British Aerodynamicist/sailor) whose published works very deeply concentrated on the fluid dynamics and aerodynamics of sailboats, the technical-sailor's "Bible", defers and acknowledges Gentry as the prime source in his later works. Sails and the lift generated by sails can only be explained by very complex 'computational aerodynamics' .... aerodynamics is simply not 'intuitive', hence the apparent confusion. Fortunately the non-aerodynamicist can SEE what is happening and 're-shape' and adjust the sails hence the "airstream flow" by the use of simple 'tell-tales' (a FULL set of Tell Tales or 'gentry-tufts') ... and simply watch an accurate speedo to validate any changes to the shape of the sails. Your sails simply wont be fully 'working' if you dont have a 'full' set of tell-tales (gentry tufts). If you want to win races such 'tufts' are mandatory -IMHO. "How Sails REALLY Work".For a CORRECT technical explanation of 'sails': www.arvelgentry.com/magaz/How_Sails_Really_Work.pdf .... warning this is VERY technical and should be read several or many times if one does not have a 'fluids' background. Read this work SLOWLY. There are other good articles on Gentry's website with respect to the 'correct' usage of telltales: www.arvelgentry.com/tuft.htm which will describe 'separation stalls', etc. etc. and other anomalies that will if ignored severely slow down a sailboat .... fortunately, you can see these effects with the usage of a FULL set of telltales. So, if you want a FAST boat , want to improve your standings in a racing fleet, want to cross oceans in 10% or 15%, etc. LESS time, outrun a major storm, etc. ..... start with www.arvelgentry.com .... all the US Americas Cup boat crews in the 70s and 80s 'memorized' every word that Gentry wrote. ;-)Hope this helps.
