Some Details
Hi Ed,..Thanks for your inquiry. Believe me, the list is long because we've had the boat for 13 years, and we've lived aboard all that time. Therefore, most of the mods have been done to make life more liveable either at the dock or at anchor (where we intend to spend the rest of our lives, now that we are finally leaving for the Sea of Cortez).Now to the details:1. By removing the settee, I mean just the seat and back; the tank is still there under the liner, as well as the locker. The two chairs mount on their swivels to the liner, and their bottoms are about 6" above it. Thus the need to build the riser for one's feet; otherwise they'd be dangling in the air.2. My radio is strictly a Ham rig, and being that I'm just a Tech, I'll get reciprocal General priveledges in Mexico.3. My engine is a 3QM30 Yanmar with aftermarket Sendure freshwater cooling. It turns a 3-blade 16" solid prop.4. The propane tanks (2- 20lb) are mounted OUTSIDE at the base of the mast where it enters the cabin. A solenoid-controlled line enters the cabin there and supplies the flash water heater in the shower and also the stove/oven. A second line goes over the cabin top along the handrail and drops in just above the refrigerator, minimizing the exposure inside. One short line; one connection. This one is controlled by a manual valve at the manifold. There is a gas sniffer mounted at floor level just opposite the fridge.5. Leading the lines aft starts with a perforated SS plate that mounts at the base of the mast (drilled & tapped holes into the aluminum fixture on the cabintop) The edges of the plate are bent up at a 45-degree angle, and has 1" holes all around. These holes receive the shackles of Garhauer (they're great!) blocks. The lines then lead to 3-sheave turning blocks on the cabintop on each side, and then to triple rope clutches forward of the winches on the cabintop. All the mounting is done with 1/4"-20 SS bolts and nuts through the cabintop with SS backing plates inside. Also, I removed the stbd mast winch, and put it on the stbd side of the cabintop. Line arrangers on the aft bulkhead, and you're all set. The lines are: main halyard, staysail halyard, boomvang,first reef (single line reefing), second reef, and main sheet.6. Head: Wilcox-Crittenden Imperial just rebuilt. Holding tank: Original and in continuous use for 13 years..I'm holding my breath! If and when it needs replacing (I'm SURE it will) I will put a new tank in the locker under the stbd berth.7. No, I didn't enlarge the anchor locker. It wasn't necessary. The Lofrans Tigres windlass fit nicely and feeds directly into the chain locker below. To get more contact on the gypsy though, I installed a roller just forward of the windlass, passing the rode under it. This works well.And no, my sheeting is as original on the bridgedeck traveller. The design is technically better, and with the dodger just fwd and the bimini just aft of the sheet, we get by (don't forget, this boat goes to sunny climes!).Hope this answers your questions Ed, and feel free (but be quick) to ask more. We'll leave for Southern waters in a few weeks.Best regards, Dave
