- Dec 30, 2009
- 680
Hey guys, I am going to buy an anchor, how r these manson and rocnas with the roll bar, as to like a cheaper one like a lewmar claw. boat is 38' approx 18k lbs. Also I see whats called a shark anchor Red
I'm in agreement with the advice so far. Switched from a45 lb CQR to a 55 lb rocna. Would not consider going back.Hey guys, I am going to buy an anchor, how r these manson and rocnas with the roll bar, as to like a cheaper one like a lewmar claw. boat is 38' approx 18k lbs. Also I see whats called a shark anchor Red
The Manson Supreme is built with a more expensive higher grade of steel than the Rocna. The Manson uses Bisalloy 80 which is what the designer of the Rocna originally INSISTED the Rocna HAD to be made from...We currently have 2 75# Bruce anchors, 400' of 5/8" chain each. If and when we decide to add an anchor, it will probably be a Manson Supreme. It would probably be a Rocna if they weren't made in China. I just don't trust the steel used in its construction.
I never said it was THE best anchor, I said it was the best anchor that FITS on my boat. As for resetting, the fortress does reset better than most Danforth type anchors simply because it sets so fast. The sharper fluke, large mud palms, and higher fluke angle all work together to make it bite and set faster than any other anchor of that design type.Horses for courses. Danforth-type anchors do not reset well when current direction changes. I'm NOT makin' this up. There's SEARCH and then there's research.![]()
