anchor type/size
321
catalina 25, 30 montauk / manhattan
cat 30 TR
need to buy new anchor.. assuming fluke but recommended weight? (also thoughts on CRQ instead?)
You're a bit behind the times on the new anchor types. Rocna and Manson Supreme have been getting very good reviews. Maine Sail did a writeup and it's included in this long thread: http://c34.org/bbs/index.php/topic,2705.0.html
Scroll through the pages to find his report - real live testing by an unbiased individual.
Jun 10, 2009
15
Catalina 30 Mark II Wickford
I went with the Manson Supreme 25 lb. Holds quick - have yet to drag. No complaints.
May 23, 2004
3,319
Bruce 33 with 30 feet of chain! It held me in a 60 knot storm a few times last summer.
I know those that swear by Manson Supreme.
I would go up a size from what the manufacturer recommends. It is just extra protection.
May 21, 2006
321
considering the manson 25lb as primary (assume most would prefer over the delta; less$).
secondary just the wm prem fluke; assuming 14lb but possibly up to the 25lb?
any suggestions on other than west marine to buy either/both?
May 23, 2004
3,319
I still suggest the lewmar version of the Bruce anchor that you get at West Marine. Put that with 30 feet of chain and you have some good ground tackle. I have spent a lot of time cruising around the Chesapeake Bay and rode out some nasty storms. I have only had an issue setting the anchor once and The next time I tried to set it in the same area it dug in and held.
May 21, 2006
321
thanks for the help.. have been doing more reading on other threads, there are certainly a lot of opinions! looks like almost all split between bruce/manson.
May 23, 2004
3,319
It is actually good to carry two different anchors. Sometimes you may not be able to grab the bottom in some areas with the primary anchor.
Rocna is a good anchor, as is the mason supreme. The bruce is a favorite of a lot of different cruisers.
I bought my Lewmar Claw Anchor (same as a bruce) from West Marine for less than $100. I then added 30 feet of chain to it for a descent price. It has held in some strong storms.
According to Lewmar, boats about my size can get by with a 22 lb anchor but I went to the 33 lb for extra hold. It also sits perfectly on the bow sprit!
May 21, 2006
321
thanks for all the advise.. one last post then I'm done!
primary option:
lewmar claw - 33lb
or
manson - 35lb (or 25lb?)
secondary:
danforth - 16lb (or do the 25lb?)
or
westmarine - 22lb (def over the 13lb? they do have the package set up with a 13lb)
another question which obviously i can find out on my own:
i'll put the primary on the bowsprit; is there room in the anchor locker then for the secondary or usually store in the cockpit?
thanks
Bob M.
Dec 29, 2007
34
Catalina 30 TRBS Chicago
Consider keeping the secondary anchor in the cockpit lazarette, ready for quick emergency deployment.
