		Sean Coerse
I'm still using the hook that came with the boat.  It has held on several overnite trips in Chesapeake muk, and sand bottoms.  The only time it didn't hold was a severe thunder storm when the wind clocked 180 degrees.  What's the largest anchor that will fit in the anchor locker on the bow.  Or did you forget the anchor locker and mount a larger hook on the bow pulpit?
