Anchor rode maintenance
Aug 7, 2013
55
O'day 39' 25th Anniversary Mystic, CT
So, among my winter projects is the fabrication of a shelf for my anchor windlass in my anchor locker, and I have been working on this project in my head for well over a year now….
Since the weather has been unseasonably warm, I have decided to start this project by removing the anchor and the rode from the locker. Now my 1st task has become assessing the rode which is laden with salt, mud, and what have you from long term storage of the anchor & tackle.
Is it sufficient and/or recommended to soak the rode in a drum of OxyClean to remove the salt and other contaminates? Followed by a fresh water rinse and then stowed for winter?
On a sunny day, I pull the chain (105 ft) and rode (250 ft of 8 plait nylon) out laying in rows on the dock, and spray it down with a hose. Let it dry then back into the anchor locker with it making sure the depth marks are still serviceable.
Mar 26, 2011
4,068
Corsair F-24 MK I Deale, MD
We'll assume rope/chain rode.
First, examine the rope/chain splice, or the slice around a thimble. Is there corrosion? A rope/chain splice typically need to be re-made every 5 years or less, due to corrosion to the chain. Cut off a few links at the same time. Thimble splices last longer, but there is still a limit. Also examine the shackles, both on the anchor and the rope/chain join. These things are far more important than washing the rope.
Rinsing the rode between cruises helps. Better than waiting until layup.
Nothing more than water is needed to remove salt. It will back the first time you use it.
Oxiclean is primarily time-released hydrogen peroxide. It will do nothing positive for the rode, as far as removing salt or lime. Nothing. It will make it cosmetically whiter, the result of gentle bleaching action, and slightly weaker. As for detergent, a long soak, with occasional agitation, will help with lime buildup, since the detergent typically contains chelating (Google it) agents. I would not recommend machine washing; there are too many ways to damage the rope and the machine. Not worth it.
  • Helpful
capta
Jun 4, 2009
5,123
From time to time, I would drag all my long lines, including anchor rodes behind the boat while sailing to clean them and work out any twists. Only one at a time.
Hot dip galvanizing is not what it once was, so whenever possible I'd recommend laying your chain out on deck or a dock and scrubbing it with fresh water, to get as much salt off as possible. Don't forget to let the chain dry and wash the chain locker, too.
