I was wondering if anyone has had this issue, and/or what to do to fix it...
I have a 2000 Hunter 290 and my anchor locker has developed a leak. The drainage through hull is about 6" from the floor of the anchor locker, so it holds water (Whomever designed this was crazy). Now, after many years of holding water, it has found a way through to the v-berth below. It seems to have seperated the layers of cloth and wood to do so. It doesn't feel or look rotten. My thought was to re-seal the inside and outside of the anchor locker. What would you do? What would you use to do so? Thanks, and remember I'm a novice at this sort of thing.
