Anchor Light
21
- - Chicago, IL
My anchor light is burned out. I have a 1984 27' Hunter. Does anyone know what the bulb type is? It will save me two trips up the Mast. Thanks
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
My 1980 has an Aqua Signal Series 25 all round light
If you can determine you have the same anchor light, then it is a 10 watt dimpled festoon bulb. Check link below. Manny
Feb 17, 2004
268
Hunter 30_74-83 Lower Salford, PA / Tolchester,MD marina
you need to be prepaired as it may not be the bulb
With boats as old as ours, mine is a 1979 Hunter 30', you may find as I did when I replaced my burned out anchor light, the the wire connecting to the socket had rusted off the post. In my case, I found it easier to replace the fixture, as the old fixture was beyound repair. Good luck with your project. Ian s/v Meant to Be
