Anchor Light
Bill Chandler
Does anyone have any wiring diagrams to help me trace the wiring for the Anchor light? The light was out when I purchased the boat and I was told that a new bulb had been installed but that did not work. I have cleaned sprayed the corrosion spots on the ground wire next to the compression post and cleaned all connections in the power station. My next stop is at the top of the mast and I really would like to eliminate all possibilities below first.
Joe Boyette
Anchor light - crimp connectors inside mast were
bad on my 1986 25.5. I went ahead and replaced the entire wire run inside the mast while I was at it.
Barry
wiring
check continuity at the base of the mast. Are you getting power to the connection at the mast base? if both are ok, then there is probably corrocion in the light at the top. Good luck and happy sailing
